Is my window motor about to die?
My driverside window will only go down/up about an inch every minute, but the weird thing is that this only happens in hot weather...what I mean is that in the morning or in cool/cloudy days it will go up/down just fine, but after it has been sitting in the sun all day, it will start doing it.
there is an overheat switch inside our window motors when your motor overheats the switch kicks on and you can no longer roll up ur windows. after a minute or so it cools down enough to roll it up another 1/2 to 1 inch til it overheats again. both of my window motors did this. replace it it only takes bout 15 minutes and the motors are like 35. i suggest a new motor not a used or remanufactured. mine was only 35 dollars brand new and came with lifetime warranty.
http://shbox.com/page/windowmotor1.html
replacing the window motor was the first repair i tackled on any car. it took me a little less than 2 hours to get the job done in the rain. follow the writeup in the previuos post and you should be fine
No special tools and yes its a bolt in installation. However Don't expect to get your first one done in 15 minutes. An hour or two maybe. Here's a write up.
