Axle C-clip removale
My axle seal is leaking so I removed the rear diff cover, drained the fluid, unbolted the pin and pulled out the center piece. I slid the axle forward as far as it will go but I can't get the Fing c-clip off to slide the axle out. Any ideas and or advice is appreciated.
Thanks to ls1silverado05
Your advice was spot on once the speed sensor was removed I had enough room to get the c-clip out. The rest of the job went well, I really appreciate the help of this board.
