AC stops blowing cold after 2 miles
Old 06-26-2009, 10:57 AM
manuel185's Avatar
Default AC stops blowing cold after 2 miles
I've been having problems with the AC on my 1994 Pontiac Firebird. When I turn the car on the air blows cold and after 2 miles it stops blowing cold (and if i turn the car off and on it works again). So I decided to take it to firestone and they told me it was cause my compressor was leaking, so they replaced the compressor. When that didn't fix the problem, they thought maybe it had to be some electrical stuff and so they decided to replace the computer and that still didn't fix it. The auto tech doesnt have a clue what could be the problem.
Has anyone had a similar problem before?
Old 06-26-2009, 11:52 AM
polarischevy05's Avatar
run a jumper wire on the low presure awitch and see if it gets cold
Old 06-26-2009, 12:44 PM
LS1vazquez's Avatar
I hate to tell you this but it's probably your fan relay that's in the fuse box. I had something like this happen in my Roadmaster and it was because the fans weren't kicking on. Something about the A/C switching from high to low or something. If you run your A/C and the accumulator is iced up, then the compressor is working.
Old 06-26-2009, 12:51 PM
camarolover209's Avatar
usually like in the winter time when i turn on my a/c to check it out and just let it run its usually has like water on it over time because of how long i have used it try it if the compressor is wet after like 20 min ur compressor is working fine its ur fan relays that are not kickin in
Old 06-26-2009, 01:13 PM
LS6427's Avatar
In just a couple miles you will not the aid of the fans to keep anything cool.
Did you check the vacuum "T" fitting over by the PCM. Make suire its not cracked or dry rotted.
Old 06-26-2009, 03:11 PM
Choppers's Avatar
you sure there is enough freon. It might be freezing up because of to little freon.
Old 06-26-2009, 03:41 PM
LS6427's Avatar
The compressor wouldn't come at all if its too low on refridgerant. And it wouldn't ever blow cold at all.
Old 06-26-2009, 09:22 PM
Choppers's Avatar
it will come on if it is to a certain point. you are wrong bout that. there is a sensor that when it reaches a certain low it won't allow it to turn on. i think if the pressure is 15 then it will allow it to come on but it will quick cycle.
Quick Reply: AC stops blowing cold after 2 miles
