Camshaft Sensor replacement from dead tach?
Here recently, my tachometer would go dead to 0 RPM when I'm accelerating moderately hard in 2nd and then it would catch back up after 5 seconds or so. It threw an SES light and it came back as the camshaft sensor. That code is PO341
Has anyone ever had this problem? Would replacing the sensor necessarily fix my tachometer problem? Most importantly, where is the sensor located and how do I go about replacing it?
Bump!
I spent the time to replace the sensor this weekend and it seemed to work for a few days but today it started acting up again and now is even worse than before. Took a 45 minute drive today and it was reading 0 about 95% of the time.
Please help! I'm drawing dead on what to do
Uh oh. I had the same problem. After replacing the sensor twice we found out that the cam had backed out some. Their was a tsb on the 03 or 04 Vettes for the same thing.
Good luck but if you're throwing the same code and your tach is going to 0 it may be the same thing.
Did the car act perfectly fine and run just as hard? I am not loosing any performance, hearing any noises, or having ignition problems....
If you're not having ignition problems it may be a signaling issue from the cps to the BCM. Their are troubleshooting steps to check that out but I have no way of posting them. They are pretty long and detailed. If you have the GM manuals for your car, they're in there.
Good luck.
