Driver side window needs a break to work?
Old 06-27-2009, 03:43 PM
01ls1lover's Avatar
Default Driver side window needs a break to work?
My driver side window works for a second.. Then stops. I let it sit then works again then stops.. I think it might be the motor? Also my passanger side is really slow.. It works but getting week. I remember a harness a while ago that fixed that.. Should i replace my driver side motor and get the harness for the passenger side?
Old 06-27-2009, 06:23 PM
Taken4granted's Avatar
Replace the motor, and check your harness
Old 06-27-2009, 09:24 PM
Pro_built7's Avatar
replace the window motor. there's a tutorial on www.shbox.com
Old 06-28-2009, 05:03 PM
Save the manuals!
wssix99's Avatar
Your motors are both dying by two different methods. Your drivers side has an issue with the thermal cutoff switch and the passenger side motor is burning out.
Old 06-28-2009, 09:47 PM
01ls1lover's Avatar
So replace both motors.. but what exactly is a thermal cutoff switch and how do I fix that?
Old 06-28-2009, 11:26 PM
Save the manuals!
wssix99's Avatar
Its an internal component of the motor. The fix is to replace the motor but... you'll want to make sure you get a new motor. Sometimes, you'll get a reman that has bad components and it will go south on you soon after you buy it. AutoZone sells a Doorman model of a new design that is supposed to be better sealed to prevent these failures. They are also new and should be more reliable than the Siemens reman units you find a lot of places.
Old 06-29-2009, 11:24 AM
01ls1lover's Avatar
I appreciate the help bro! I will get some motors when I get some money. So maybe by year 2234 I can fix it.
Old 06-29-2009, 02:26 PM
Save the manuals!
wssix99's Avatar
The nice thing is that once you get a new motor, they come with a lifetime warranty - so you don't get hit when you have to replace them over and over and over again!
