SES Light Started Flashing - Please help
Hey guys,
Yesterday i was driving around town and I noticed my car wasn't running right. At an idle or going slow it was fine, but when I hit the throttle it didn't go anywhere near as fast and smoothly as it should have. It almost felt like it was popping/ticking and struggling to accelerate. It didn't bog down or anything, it just struggled.
Today I drove 5 miles and my SES light started flashing. The car still feels very weird. Has anyone had a similar problem?
I need to find somewhere to run the code.. Does Advance Auto parts run codes? I'm guessing any service station can right? Also is there a guide with all codes listed so I can figure out what it is?
Thank you
Thank you
You should be able to get it scanned for free at Autozone. Or if you know someone with an OBDII scanner then they should be able to scan it. Here is the list for the DTC codes. Good luck figuring out what's wrong with it.
https://ls1tech.com/forums/general-m...ght-codes.html
hi, when your ses light is flashing it usually means your having random multiple misfires. i had the problem when i first put headers on. when you get it scanned they should be able to tell you which cylinders are misfiring. start with plugs and wires. then check coils. good luck
Will the SES light eventually turn off, or do I have to get it cleared at a service station?
Thank you guys!
go get it check to make sure it was that cylinder that was a missfire and get it cleared it wont go off my its self unless you reset the ECU (disconnect battery for 5 min)
