Stuck throttle
Old 06-30-2009, 10:34 AM
NonGoggleGuy's Avatar
Default Stuck throttle
2000 T/A Firehawk.
So my throttle stuck wide open Sunday. Wasn't expecting that. A little scary. It's not a NW or FAST. I have a stock un-modded TB.
I had to shut the car off, open the hood, and unstick it manually. It didn't do it again, but when I got home, I put a bunch of oil on the mechanism & played with it a little.
Just thought I'd post to see what other people might have to say about it.
Old 07-01-2009, 09:39 PM
VTEC-THIS's Avatar
open the throttle body and clean behind the throttle blade with some carb cleaner on a rag. give it a shot
Old 07-02-2009, 06:53 PM
blade2222's Avatar
also around the bore where the throttle blade is.
Old 07-04-2009, 04:08 PM
rg501's Avatar
when i cleaned my TB, i took an old toothbrush and sprayed throttle body cleaner (seafoam deep creep) on it and scrubbed the sides, blades, and the bore like blade2222 mentioned. before i cleaned the TB, my throttle pedal felt sticky and now it doesn't.
