92 Camaro starting issues
Old 07-12-2009, 06:50 PM
Nippins's Avatar
Default 92 Camaro starting issues
I know I have a solinoid issue as the bendix does not engage the flywheel properly.
BUT what has been happening a few times is that I will run the car to some destination and shut it off.
When I go to restart, nothing happens other then the gauges showing me the the ignition switch is engaging.
No relay clicking, no solinoid engagment. Nothing.
After a few min to maybe half hour, everything engages.
This has happened 3 times already within a week.
I plan on repalcing the started I think but will that solve this issue????
Old 07-13-2009, 12:10 AM
SlideRight's Avatar
When you turn the key over does the dash go dead? My "95 has don that a few times too.
Old 07-13-2009, 07:13 AM
Nippins's Avatar
The dash does NOT go dead.
There is just NO starter action.
All the other electronics appear to work.
Old 07-13-2009, 11:53 AM
SlideRight's Avatar
Ahh. GL on the fix.
Old 07-13-2009, 04:44 PM
Giggity's Avatar
I had a 91' that did this and it was the VATS that was causing the problem. I think it locks it out for 10 min or something if it doesn't see the right resistance in the key. I ended up bypassing mine.
