How do I replace the evaportator?
Old 07-15-2009, 03:36 PM
6LITEREATER's Avatar
Default How do I replace the evaportator?
Well, $1000 later (A/C compressor, new dryer, new condesnor, etc...) my A/C starts blowing hot two days after I get it from Firestone.
I take it back in, they said they had flushed it but my compressor had blown out really bad and there was debris all through the system, may have still been some in there.
They reflush it, replace oraphice (sp) tube again, recharge it. They say if it does it again I will have to replace the evaporator myself (they won't do it) and bring it back for a free tube and recharge...
SO, you can guess what happened by the title of the thread...
Where is it exactly (is it what is on the firewall)? What do I have to do to pull to get to it (do I have to pull dash from inside?)?
Thanks...
Old 07-15-2009, 05:29 PM
fleetmgr's Avatar
Yes, it's the box on the firewall - you take the box apart to replace the evaporator. The evaporator is the A/C equivalent of a heater core, as in that where the heat is removed from the air that blows in your face.
Old 07-15-2009, 05:45 PM
So do I need to pull the dash to get to anything from the inside?
Old 07-15-2009, 06:16 PM
fleetmgr's Avatar
no, not required
Old 07-15-2009, 06:23 PM
How do I pull it then? Everyone is telling me I need to pull the dash and vents to get to it... Thanks for the help.
Old 07-15-2009, 06:52 PM
fleetmgr's Avatar
I'm going by what Alldata says about it, and I found a little problem with their info. They don't talk about pulling the dash in their section on it, but based on the time allowed by them (over 6 hours) I'd say you WILL have to pull the dash. Sorry for the goof!
Old 07-15-2009, 07:00 PM
^^You got my hopes up
I've already done the dash once (converted to ebony), guess it will now be twice...
Old 07-15-2009, 08:53 PM
LS6427's Avatar
Holy mother of god....$1,000, and at Firestone. Probably what...a 90-day warranty.
I paid the dealership $800 5 years ago, and got a lifetime parts and labor warranty. I'll never pay a penny again for an A/C problem.
Old 07-15-2009, 09:13 PM
And that was with 15% off!!!
Old 07-15-2009, 09:23 PM
fleetmgr's Avatar
WOOHOO!!!
Old 07-15-2009, 11:08 PM
99RTA's Avatar
Do yourself a big favor and find a better shop. If the compressor really came apart and pushed garbage all through the system you will need to install a filter in the high pressure line before the Orifice tube. They make them that install with compression fittings. It will catch all the crap before it blocks the orifice tube screen.
Most good ac shops do this to save the agravation you are going through. read over this page....its what you need http://autoacrepairs.com/ac_in_line_filter.htm
Old 07-16-2009, 02:46 AM
TireSm0ke's Avatar
I looked it up on alldata as well, and your right about it not showing pulling the dash. The only problem is to access the evaporator you need to pull it through the interior with the dash removed, unless im mistaken. I still cant believe they did all that work with replacing the evap. Ill give u a call tomorrow Mark I got a price on the part from my supplier.
Old 07-16-2009, 04:03 AM
Thanks Evan... Yeah, pisses me off that they are fine being half assed about it AFTER I already spent my money there.
I took it here to just pay and not worry for once. I told them replace whatever you need to to make sure it is done right an warrantied. ******* then pull this "we can't replace that, you have to do it yourself" bull **** and you know later they'll say it isn't warrantied because I did it...
Old 07-24-2011, 07:56 PM
3800RS's Avatar
any shortcut on doing this ?
Old 07-24-2011, 07:58 PM
FiredUpZ28's Avatar
Good lord man, you paid 1000 dollars and it doesn't sound like your issue was ever actually diagnosed properly. How bout trying another shop? Its rather that, or start yankin the dash. There really isn't much to GM car interiors as long as you remember what went where. Plastic non-marring prybars help a lot too.
Old 07-27-2011, 01:57 PM
92SilverSHO's Avatar
6liter, your a sponsor!!! your supposed to take it to another sponsors shop and have them do it for you and give them some free parts in exchange!!. Im sure someone more reputable here would have done it better and possibly cheaper.
Old 08-01-2011, 03:27 AM
Ummmm.... thanks for the help guys but you realize this thread is two years old right, lol?!
Old 08-04-2011, 08:02 AM
3800RS's Avatar
i did, just wanted to see if there was an easier way.... there wasnt. Pulled my dash last weekend and it sucked
