SES code - Is it the cats?
Since I have had the car out of storage for this summer, I have been receiving SES code P0430 which is the catalyst system efficiency below threshold (bank 2). I normally clear it myself, cause im sick of looking at it.. The car has not been under powered or non responsive when I hit the gas, as others have complained of when this code is present. However, I do need to pass an emissions test next year and I have been doing some research and most people say its probably my passenger side Cat that is throwing the code. The car only has 18600 miles on it and the cats are SLP, who we're installed by the previous owner. I hate to replace the cats, since I'm assuming they are new, but I don't want to fail the test either. In the mean time, am I causing any trouble to the vehicle, when I clear the codes and continue to drive until they come around again? They come around approximately every 30 start ups or so. So its not to often, as others have complained of clearing the code, then the next drive it comes back. Also, if you guys think its the cat, does anyone know where I can buy 1 cat? Everywhere I look, they are sold in pairs, and since they are so expensive, I would love to just buy 1. Thanks for your help and suggestions ahead of time.
Jason
Jason
Car doesn't have to be perfect to pass Ontario emissions.
Clear the code and give it a try, it might pass as is.
Are the SLP cats direct fit, or are they the small ones that are welded in?
It might be cheaper to buy 2 used cats than one new one. A new aftermarket direct fit cat is $250 if I remember correctly.
Good luck!
Good luck!
The SLP cats are direct fit, with the clamps holding it in place. To me it doesn't look like their are any welds.. Just 2 clamps on either side holding it in place. But I guess my main concern is that.. am I harming the car by continuing to drive it and just clearing the codes everytime they come in?
Thanks
Thanks
Well lets pray lol. If I put in oem cats with my headers will my chances of passing be higher? But anyway I just don't want to spend too much money to pass.. stupid emissons test..
i am getting the same code < so its my passenger side cat ? the one right under the passenger seat right? so if i cut it off and clamp on a high flow cat the SES light will turn off and i will pass emisions????????
What you can do to pass emissions is buy a set of "spark plug anti-foulers"... They're made for spark plugs obviously, but if you buy the one with the bigger threads, you're O2s will thread right in. All you have to do is...
1. Buy a set of two. (any auto parts store)
2. drill one of them out... so you can fit the O2 sensor inside of it.
3. screw the two into each other.
4. unscrew O2 from your O2 bung, and thread the anti-foulers in.
5. Then screw your O2 back into the anti-foulers.
Clear the code.. and you're good to go. We just did this on my buddies Audi A4.. The new cats would have costed him about 2 grand... The spark anti-foulers? About $20.
I do know how it works... PO430... Is a test that your car runs to see if your cat is sufficient... What your car does is dump a little extra fuel... And sees if the cat drowns out the extra gases... Your front o2s will cross count...(rich lean rich lean rich lean) and your rear o2s should flatline.... Since they are after the cat. Basically your cat isn't working perfectly under the tests conditions. All we are doing is forcing those rear o2s to flatline... Which gets rid of your code.
Now when you go to get emissions tested... You shouldn't have anything to worry about... Since your car isn't dumping extra fuel in there... You shouldn't have any extra emissions.
