its hot here an my AC isnt working! HELP PLEASE!!!
Old 07-16-2009, 04:11 AM
UnZFeat'd's Avatar
Default its hot here an my AC isnt working! HELP PLEASE!!!
Ok, so my AC, when turned on, just pumps air out of the bottom vents by the floor. Nothing coming out of the vents that face the driver (the important ones). Not even hot air. Just no air at all. Anyone have any ideas about what it could be? Thanks
Old 07-16-2009, 06:27 AM
firetpi's Avatar
check your vacuum line near the back of the intake going to the hvac controls. may have popped of.
Old 07-16-2009, 07:31 PM
UnZFeat'd's Avatar
back of the intake manifold? thats all good. I just recently did an LS6 intake swap and made sure, but this problem has been happening even before i did tha swap.
Old 07-16-2009, 07:45 PM
LS6427's Avatar
Check the "T" valve over by the PCM.
Old 07-17-2009, 12:19 PM
xbcrguy182x's Avatar
YES! That always cracks. It's like a $6 part. Easy to change.
It's called the vacuum check valve.
Old 08-04-2009, 09:14 PM
kawasakiklx's Avatar
The line that says "To mode selector on dashboard" where does the line plug into, the firewall? My vents dont change with the switch and that line is loose, cant find its connector.
Old 07-08-2010, 01:00 AM
Apex8's Avatar
Did yilou ever folind the issue? I'm having the same thing
