overheating traffic
Old 07-20-2009, 10:42 PM
djkeene16's Avatar
Default overheating traffic
ok so my 2000 trans am overheats in traffic?? i can drive the same 40 miles at 80 mph with the ac full blast and its fine, when im stop and go its shooting fluid out the overflow.. what do you guys think
Old 07-21-2009, 12:22 AM
casca2001's Avatar
First thing i would do is check to make sure your fans are coming on
Old 07-21-2009, 08:46 AM
TooLateVTEC's Avatar
Yep, check the fans and check the air dam underneath the front end.
If those are good, take the lid/filter/filter box off and look down into the radiator and check for dirt/debris. Clean it out as necessary.
Old 07-21-2009, 10:20 PM
01ssreda4's Avatar
i agree, sounds like a fan issue.
Old 07-21-2009, 10:34 PM
neutron82's Avatar
take a look at the a/c condensor... if it has a bunch of crap stuck in it that may be your problem... fans could be a problem also as stated above
Old 07-25-2009, 04:01 PM
djkeene16's Avatar
Thanks for the help it was the fan relays u guys kick ***
Old 07-25-2009, 04:16 PM
oldstyle81's Avatar
im having the same problem on my 2004 GTO, its at the dealer now
