box under driverside frame rail?
Old 07-21-2009, 11:43 PM
TurboZ28408's Avatar
Default box under driverside frame rail?
what is this box under my driverside frame rail? it has a cable coming out of it so i assume its cruise control ? how would i go about removing it ? is there a cable to unhook inside the cabin and remove the unit ?
Old 07-21-2009, 11:48 PM
LS6427's Avatar
Can ya get a pic of this thing?
Old 07-22-2009, 07:43 AM
AFASTYZFR1's Avatar
sounds like cruise control
Old 07-23-2009, 03:15 PM
Yourlope'sajoke's Avatar
its the pump for the AIR system, I had a picture but i can't get on Techline. But just to make sure were talking about the same thing, comes out the firewall and is holding the brake-line holder in place. It basically opens and closes the valve that releases pressure from your crank case.
Old 07-23-2009, 03:24 PM
here we go, this should help, It basically gives pressure to the AIR valve and circulates the gasses through the crank and head covers.
