running engine with broken oil pressure sender/switch? need answer ASAP please
Old 07-22-2009, 08:49 PM
therealcreeper's Avatar
Default running engine with broken oil pressure sender/switch? need answer ASAP please
the piece that always breaks when you swap intakes. friend of mine broke his and can't get a new one for a few days, but needs his car.
will it hurt anything or just cause the oil pressure gauge not to work?
Old 07-22-2009, 09:17 PM
Giggity's Avatar
On my 3rd gen the fuel pump would shut off if it didn't detect oil pressure a few seconds after startup. Not sure if that's a separate sensor/switch on the 4th gens. Other than that I would only be worried about not knowing if you lost pressure, but I guess it wouldn't hurt anything.
Old 07-22-2009, 09:47 PM
okay thanks. i've read a few posts saying it's not linked to the PCM but i can't find anything solid.
Old 07-22-2009, 10:31 PM
XtraCajunSS's Avatar
You won't have a problem driving it with a broken sensor, I've seen more than one Corvette or F-body driven here with broken or bad sensors for me to replace.
Shane
Old 07-22-2009, 10:57 PM
okay thanks for the quick replies
Old 07-24-2009, 03:52 PM
1999Transamman's Avatar
Itll work, I remember when I busted mine, it looked like it was just a clear diaphram that was keeping the oil in, so I would keep it to a minimum and definitly not push it to hard, but it should hold out.
