Help!!! Misfire
Old 07-25-2009, 08:05 PM
tcondra's Avatar
Default Help!!! Misfire
I have a 98 camaro , I was driving it home car was running fine doing about 60. Got off on to a main road and slowed down to about 35 and the car started missing and pulled the ses light then it started flashing. I got it home and run the codes po 307 #7 misfire, po351 coil 1 malfunction, and a po353 #3 coil malfunction . Changed all plugs and put in new ngk tr55, and two new coils, now still got the #7 misfire. Any suggestions?
Old 07-25-2009, 08:16 PM
LS6427's Avatar
If you have no other codes except #7 misfire....just make sure BOTH wire ends are "snapped" on good to the coil and the plug. Also, make sure the plug wire(s) are not touching the manifold pipes. Possible cracked spark plug in #7.
Old 07-25-2009, 08:38 PM
tcondra's Avatar
new plugs and msd wires. both ends snapped on good. i have had them come lose before so i check them often
Old 07-25-2009, 08:42 PM
LS6427's Avatar
Is it misfiring at all rpm's? Or just mid to high?
Swap the wires around see if that changes the misfire cylinder?
Old 07-25-2009, 08:45 PM
tcondra's Avatar
the car misfires at idle and if you rev it up. changed the wires around to still #7 misses like hell
Old 07-25-2009, 08:51 PM
LS6427's Avatar
Next step then, take the plug out and make sure its not cracked. I'd also swap #7 fuel injector to see if the misfire moves with it.
Old 07-25-2009, 08:53 PM
tcondra's Avatar
thanks i'll try that next
Old 07-26-2009, 01:20 PM
tcondra's Avatar
just found out that i broke some valvesprings!(again???). i just can not figure out why this keeps happening? some friend who work on cars said someone has put a bigger cam in it and did not change the valve springs. could this be the cause????
Old 07-26-2009, 01:32 PM
LS6427's Avatar
Yes. Also, getting on it hard (high rpm's) before the engine is warmed up, with high lift, can cause them to break.
Old 07-26-2009, 01:35 PM
transamman08's Avatar
yes if someone did put a bigger cam in, then yes thats most likely the problem
Old 07-26-2009, 02:03 PM
tcondra's Avatar
when i started pulling it apart we found that it has lunati push rods in it and noticed that it has new gaskets on the timing chain,heads and intake.just wish i could find out what springs i need to stop this.
Old 07-26-2009, 02:13 PM
LS6427's Avatar
I assume you have double springs?
Old 07-26-2009, 02:28 PM
tcondra's Avatar
they are stock i guess? i need to get new springs,retainers and locks to be safe. i just dont know what to get?? any help!!
Old 07-26-2009, 02:44 PM
LS6427's Avatar
Holy ****...things could have ended badly. Dropping a valve.
Old 07-26-2009, 02:45 PM
LS6427's Avatar
Have someone tell you what size cam you have, then get springs to match. Its easy.
Any good head shops around you?
I have Crane double springs in mine. .610 lift
Old 07-26-2009, 03:07 PM
tcondra's Avatar
how can you tell what size cam with out taking the cam out?
Old 07-26-2009, 03:19 PM
LS6427's Avatar
I don't know, but I can only assume there's a way using the some super duper tool on the springs/valves.
Ask in a new thread in the "Internal Engine" section. I'd like to know too.
