GM part number for window/door seal?
Old 07-26-2009, 02:10 PM
jb442's Avatar
Default GM part number for window/door seal?
I'm trying to locate the GM part number for this seal:
Based on the design, there should be a LH & RH part number.
I have a 93-02 parts manual CD, but could not locate this seal.
The picture is of a 95 Z28 (non-convert), but may be the same 93-02.
Thanks for your help, John.
Old 07-26-2009, 06:25 PM
whitehooptie's Avatar
Closest thing I see is10260335 for rh and 10260336 for lh. It is under the Door hardware section body group 10
Old 07-26-2009, 07:15 PM
jb442's Avatar
Thanks! I somehow missed that section. That does look like the right part numbers because of the pins (8731909) that are shown in the diagram.
Old 07-26-2009, 11:05 PM
No problem man. I know that GM's stuff is a little weird to understand.
Old 07-27-2009, 03:56 PM
99monguse's Avatar
What you are looking for is 10414267 lft and 10414266 rt side. The retainers for these seals (trims pieces) are part number 8731909. The actual trim pieces are discontinued but can be gotten from VPI (VINTAGE PARTS INCORPORATED)through your local dealer. I don't know if you can buy them from GMPARTSDIRECT or not. I am a GM, VOLVO, and Mercedes parts counterman.
Quick Reply: GM part number for window/door seal?
