Tranny Seal
Old 08-24-2009, 11:08 AM
Midnight00SS's Avatar
Default Tranny Seal
Noticed today on my t56 that it was wet wit oil where the end of the tailshaft is im guessing those seals go bad??
Old 08-24-2009, 01:33 PM
fleetmgr's Avatar
Yup, they do. They are also easy to change.
Old 08-24-2009, 01:36 PM
BlueBird346's Avatar
Mines leaking too. Does it just slide out?
Old 08-24-2009, 09:16 PM
joecar's Avatar
If you have many miles, then also check the bushing on the back of the trans... if it is worn then this will allow the yoke to wobble which will cause the seal to leak.
Old 08-24-2009, 11:42 PM
how do u change this thing?
Old 08-25-2009, 08:47 AM
fleetmgr's Avatar
Remove the seal with a seal remover, and tap the new one in. Same as a wheel bearing seal.
The bushing behind the seal takes a special puller/installer, but Joecar is right, you should change it too.
Old 08-25-2009, 11:18 AM
ok so i should prob replace both?? it cant be too expensive im guessing?
Old 08-25-2009, 01:33 PM
fleetmgr's Avatar
Naw, it's not expensive....and I think you can rent the puller from AZ and the like.
Old 08-26-2009, 12:22 AM
ok cool then will do
Old 08-27-2009, 02:22 PM
Would this seal also be called an "extension housing seal". Thats what ive found on GM parts direct, just wondering if its the same thing.
Old 08-27-2009, 03:24 PM
fleetmgr's Avatar
Not sure, but something like that I wouldn't get from an online site anyway, for a couple of reasons:
1. From the parts store, it'll be less than $10.
2. You can't match it with the old one.
3. There's no good reason to pay the extra to have an OEM seal. They buy theirs from the same manufacturers the parts stores do.
Old 08-27-2009, 04:43 PM
Eatinstang4life's Avatar
I am in the process of doing the same thing. I cant find the Bushing though on AZ site.
Old 08-27-2009, 06:07 PM
fleetmgr's Avatar
Go to NAPA
Old 08-27-2009, 11:40 PM
yea i think i will replace both then
Old 08-28-2009, 12:04 AM
O reillys said they cant get them, neither could the other parts houses. They said go to the GM dealer. My local Chevy dealer wants $53 for one. So I looked on GM parts house and its only $8. If thats the same part.
Old 08-28-2009, 08:31 AM
fleetmgr's Avatar
You might also look at some of the site sponsors here, like D&D. Bet they got 'em.
Old 08-28-2009, 11:02 AM
wut is the part #'s that we need for the both of them??
Old 08-31-2009, 06:48 PM
just replaced the seal and bushing part number 5200 at Advanced and AZ $7.99. the bushing is really tight though. Im thinking once I put a few miles on in the driveshaft will break it in.
Old 08-31-2009, 11:37 PM
Looks like im going to Advanced tomorrow. Was it hard to do?
Old 09-01-2009, 02:25 PM
No, took a lil while to get the bushing off. I did not have a puller so I bent the tip of a skinniy flat head and just kept pulling on the back of the bushing and a little banging and finally got it. Just a regular seal puller will do the trick for the seal.
