maintainance for a Camaro ss at 100,000!!!
Old 08-31-2009, 12:19 AM
mvaldezss's Avatar
Default maintainance for a Camaro ss at 100,000!!!
The vert SS is finally at 100,000 miles and it has come time for me to do some maintainance though im not sure exactly what? so far i have done the following...
changed oil every 3,000miles, did a coolant flush, had the tranny serviced, brakes and pads changed. What else do i need to do?...
Old 08-31-2009, 12:22 AM
hitmanws6's Avatar
full tune up (plugs etc)
Clean out your top+bottom end
Clean injectors
New diff fluid
Shocks
Check Bushings
Check tie rods
Old 08-31-2009, 07:03 PM
mvaldezss's Avatar
thanks alot for the info..i will be sure to get this done, however should i get this stuff done at a shop or is it easier to do myself?
Old 08-31-2009, 07:30 PM
transamsam98's Avatar
do it yourself its fun and ur a ***** if you take it to a shop. no but realy why not take a stab at it if you have basic hand tools and jock stands and a tq wrench its all very easy
Old 08-31-2009, 08:56 PM
mvaldezss's Avatar
haha yea thats true, a lot cheaper too i bet
Old 08-31-2009, 11:13 PM
Prediluted's Avatar
It is much cheaper.
Valvoline wanted $100 to just swap out my differential fluid...
Old 08-31-2009, 11:37 PM
hitmanws6's Avatar
Originally Posted by Prediluted
It is much cheaper.
at work its 50 bucks or so, but to the op you can do all these things by yourself
Old 09-01-2009, 07:29 AM
slow's Avatar
rear LCA bushings are likely shot with 100K on them
Moog replacements (1LE equilivent) made a huge difference in my car.
swaybar end links, and bushings should be looked at as well.
Ryan
