LT1 WS6 TA been stored...gas in tank?
I have a friend who has a 1996 Trans Am Ws6 thats been sitting in her garage for a couple years without being started or anything. She doesn't know anything about cars except how to put gas in them and give them an occassional bath. She had some serious relationship issues with her boyfriend and was forced to park the car; she parked the car without fuel stabilizer. I am thinking that it will be a very bad idea to start that car with 2-3 year old fuel(that has been stagnant). I don't know how long it takes for gas to turn bad. Does anyone know if the 96 LT1 F-bodies had drain ***** on the fuel tanks? What do you think I should do to help her get this car driveable? If theres no drain **** then maybe I can just use a manual pump like what you use for a water bad, and just pull the fuel through the filler pipe?
She wants to drive the car but doesn't want to cause hurt to it either; she finally got hid of this guy and she can drive her car again.
While it probably won't hurt anything if it gets used, the car may not start to begin with. And if it does, it'll probably run like crap. If all else fails, go to AZ and get an Oklahoma credit card (squeeze siphon pump). Gas shelf life can be as short as 6 mos.
I was thinking that I could just disconnect the fuel feed line and add a hose to it, then jump the fuel pump relay and pump it out. BUT I don't really want to run that **** through the pump. I called my local ACE HARDWARE and they carry hand-pump siphons of gasoline for like $5.00 so I think I will go that route!
Takes a hell of alot more than 2 months for gas to go bad, unless its sitting in a bucket or other totally open container.
I always carry a 1 gallon gas tank in my back compartment. I ran out of gas last month and had to use that to get myself to a gas station...that gas was well over 1 year old. If its sealed it will last for years and years.
99monguse,
How much gas is in the tank now?
If its less than 1/2 tank I'd take the gas cap off and put my nose up to the filler neck, if it has a strong smell of gas I'd crank it up. If it runs fine, drive it to a gas station and fill it up. Put a full can of Sea Foam in there too.
You should certainly change the oil right away.
99monguse,
Yea idk where your getting the gas goes bad in 2months thing.. I store my trans am every winter from around november- april or may, ill start it up once a month usually to let it warm up so the battery doesn't die, and the gas is always fine. I fill it half way and leave it there to last the entire 6months.
From what i've read, gas *starts* to deteriorate after 2 months of sitting. I didn't mean to say it is totally bad after 2 months. I've had a lot of experience running engines on old gas.
Oxidation and water damage from condensation can occur in a car's gas tank. A car could run (not very well) on 2-3 year old gas, but it's not worth the risk of F*ing up the fuel lines and injectors, especially in a nice WS6.
CNN gas report
CNN gas report
CNN gas report
CNN gas report
I wonder if this is true. At my dealership(we are a Buick dealer) and we have a pump tank to remove fuel from cars tanks but its not a power pump. All you do it turn the handle like a churn...basically like a siphon and we use this on cars all the way to 2009 models. For $5.00 I'll try the siphon
Again as you can see if this were my WS6 or even my girl; the poor car wouldn't be in this situation.
Ah! That's interesting. Try it though, and let us know.
