oil change
Old 09-06-2009, 08:17 PM
c5z28's Avatar
Default oil change
Go easy guys okay. I changed the oil today used wix filter and mobil1 10w30. Made sure all the oil was out etc jacked the front of the car to get underneath it, also jacked up the back end to get it level and waited for the dripping to stop. So last time I changed it I used damn near 6 quarts and the dipstick showed the oil over the arrow. So this time I put in 5 and 2/3 quarts and got to about the same level. Just wondering how much you guys put in the car, mine has sat for an hour and the oil is just over the back end of the arrow (operating range). It probably is not that accurate but I want to make sure I have not put to much in.
Old 09-06-2009, 08:27 PM
fleetmgr's Avatar
Start the car and fill the filter up, check for leaks, etc. then check the level again...top off as necessary.
Old 09-06-2009, 08:39 PM
LS6427's Avatar
I always dump all 6 qrts in.
Old 09-06-2009, 08:45 PM
c5z28's Avatar
That's what I did last time but looking at the dipstick the oil was always above the operating level, where is your at?
Old 09-06-2009, 09:08 PM
LS6427's Avatar
I have my dipstick segmented with lines that I put into my dipstick with a file. I have a 3.5 line, 4, 5, 5.5. So when I pour all 6 qrts in it really never gets above the 5.5 mark....because some of the oil always sticks to everything in the engine. There's no way on earth 100% of the oil can make it back down to the pan. But I know there's 6 qrts in there. There's absolutely nothing wrong with putting 6 qrts of oil into a stock LS1 oil pan.
But like "fleetmgr" said, start it up so the oil filter gets filled up. But you'll have to wait a good 15 minutes to get an accurate reading. If you do it after its up to operating temp, you can wait just a minute or so and then check it and it'll be pretty damn accurate.
I always fill my new oil filter to the top with new oil before I screw it on.
Old 09-06-2009, 09:13 PM
c5z28's Avatar
I always forget to put oil in the filter but hey atleast I remember to make sure the old oil filter gasket is out my neighbor made that mistake twice
Old 09-06-2009, 09:21 PM
SparkyJJO's Avatar
Wish I could do that on my 6 but the filter goes on horizontally so it isn't possible.
Old 09-06-2009, 09:42 PM
LS6427's Avatar
Old oil filter gasket.....its permanently attached to the oil filter
Old 09-06-2009, 10:22 PM
hitmanws6's Avatar
sometimes it gets stuck to the pan, you dont realize it so you put the new filter on. you have just double gasketed. it usually results in oil everywhere since the filter doesnt seal properly
Old 09-06-2009, 10:23 PM
hitmanws6's Avatar
and to the op, the general rule of thumb is 5.5 qts with the short filter, 6 with the longer one
Old 09-06-2009, 11:16 PM
c5z28's Avatar
Thank you for that info I asked the guy at the parts place if they had any bigger oil filters he looked at me like. Are you speaking for your lt-1 or is this for both?
Old 09-06-2009, 11:19 PM
c5z28's Avatar
Yep saw where he had driven to drop his kids off at school and where he truned around when he realized he fucked up
Old 09-06-2009, 11:37 PM
hitmanws6's Avatar
i think there is a bigger filter used on the LQ blocks, not sure about the part number. but for my LT1 there is the standard filter and then the truck filter which is twice as long
Old 09-07-2009, 12:06 AM
LS6427's Avatar
Never heard of that. I always put wet oil on the gasket before I put it on...ain't no way that sucker will stick when I take it off. I also only leave them on for 3,000 miles, and for me, thats about 2 months of driving.
Old 09-07-2009, 12:15 AM
hitmanws6's Avatar
its very rare. ive seen it happen once.
Old 09-07-2009, 03:21 PM
c5z28's Avatar
I said my neighbors car different make etc. No big deal
Old 09-07-2009, 03:50 PM
LS6427's Avatar
I said to my neighbors car different make etc. No big deal
what?
Old 09-07-2009, 03:52 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
5.5 to 6 qts. Depending on filter.
Old 09-07-2009, 04:17 PM
LS6427's Avatar
I have always put the whole 6 qrts in and I have also always used the smaller OEM filter.
Old 09-09-2009, 01:15 PM
c5z28's Avatar
what?
fixed, was just saying my neighbors car was a different make hence different variables. Excuse me I have been hopped up on robutussin for the past few days.
