Removing oil pan
Old 09-13-2009, 06:07 PM
cure07's Avatar
Default Removing oil pan
hey guys. I need to kno the best way to remove my oil pan. Ive been having starter issues and need to check inside the engine. so let me kno what the best way is thnx!
Old 09-13-2009, 10:51 PM
klujan13's Avatar
I didn't use a write up I just figured it out on my own but it is a pain let me warn you. I unbolted the motor mounts and lifted the motor up as high as I possibly could with a jack from under the car, then I placed a section of 4x4 wood in between the clamshells and the frame. It fit perfectly in between the pedestols then I lowered the engine back down til it rested on the wood blocks luckily there was a big enough gap between the k-member and the pan slid out toward the back.
