Power steering whining
My power steering pump is LOUD when I make turns and accelerate at the same time. It works fine so I don't think my pump is going out, I do think I've got air in the PS lines though, so how do I get the air out? I've heard of a procedure where you turn "lock to lock" with the front wheels off the ground, could someone describe this procedure to me though? Thank you
so to get rid of the old fluid you basically like pump it out? then you move the wheel 8 times lock to lock and you said until the bottles empty? so how does the bottle empty do you have to keep pumping it out? sorry i may not be getting this kind of dumb about this lol
we dont drain it. we have a bottle of power steering fluid with us. we suck out all the old fluid, then refill it with new fluid from the bottle. we then turn the wheel 8 times "lock to lock". then we repeat. we do it until we empty the bottle. the ones i have done have completely changed the steering of the car
lol.. We have the BG power steering flush machine... If you drain the resevior and refill it, then turn the steering wheel back and forth the resevior is going to fill and mix old and new fluid, then we drain the resevior again and again and again and again, until 99% of the fluid has cycled and is brand new.... we also use a cleaner first to get all the gunk up.... its like 60 bucks at most shops... you may just be low on ps fluid from a leak!
EDIT, we have a machine that runs off the air compressor that will suck out the old fluid with a small tube, then fill it with another tube...
damn man im sorry i dont have special equipment like that. I apreciate your input I really do, but I'm wondering how to get the fluid out with standard tools, I need a way to drain the fluid and was just wondering if there was a way to drain it without being detrimental to what I'm trying to do
I got that same whine. I like to pretend its a supercharger...hahaha. It does bother me, but the steering works just fine. I just figured on replacing the fluid and seeing how it goes. Let me know if it works for you. I also notice that after a week or so, it pushes a little bit out the top.
