A/C Blower Motor Noise
My A/C blower has started making a horrendous hum/drone when turned on, it gets louder when the speed is turned up so I am 99% sure the blower motor is starting to go out (bearing rubbing maybe? CPU fans do similar noises when their bearings start to go out). My question is how/where do I replace the thing? I can't find anything on it in the Hayne's Manual, and I've never done ANYTHING to the A/C or climate control in any car I've ever owned.
I just replaced mine recently. The humming you are hearing might be caused by some of the plastic blades being broken off and throwing the motor out of balance. Mine sounded like it would rattle the dash apart if I turned it passed 2. The motor is located on the passenger side under the glove box area. You will have to remove the plastic kick guard under the dash. The motor is held in by three small bolts and there's an electrical connector attached to it. It took about 10 minutes to swap it out.
