CYCLO ENGINE LEAK STOP WILL be harmful to engine?? or useful for leakage
Old 10-05-2009, 03:22 PM
ZSU
ZSU's Avatar
Question CYCLO ENGINE LEAK STOP WILL be harmful to engine?? or useful for leakage
CYCLO ENGINE LEAK STOP WILL be harmful to engine?? or useful for leakage???
they claim that wont harmful engine
http://www.cyclo.com/system/images/Techdata/C89TDS.pdf
Old 10-05-2009, 05:20 PM
91RS383's Avatar
Don't use any type of stop leak. If your engine leaks fix the leak. All those additives are snake oils designed to do one thing, make your wallet lighter.
Old 10-05-2009, 06:53 PM
fleetmgr's Avatar
Absolutely correct...don't put that crap in under any circumstances unless:
1. you are selling the car, and don't care how bad you screw the next guy.
2. You have DEEP pockets and don't have the time at the moment to fix it right.
The problems caused by this stuff are many times worse than the ones it's supposed to cure.
Old 10-06-2009, 05:17 PM
ZSU
ZSU's Avatar
they claim it wont be harmful to engine.. thats why Im confused.. its really hard to change gaskets they need to take down my cars engine :/
Old 10-06-2009, 10:02 PM
eseibel67's Avatar
These guys are right. Stop leak will damage your rad, heater, and more. No matter what it says on the can.
Edit; Sorry, I see it's oil stop leak, not coolant. Same answer anyway. Don't use it. It swells gaskets and damages them.
Old 01-17-2020, 09:21 AM
Fah Cue's Avatar
Just looking through old threads.
About ten years ago I saw an episode of myth busters where a guy had a small hole in the radiator.
well I followed what they did and it sealed my radiator long enough to finish my 600 Mile drive.
Laugh all you want, but it worked and it got me home.
I opened the radiator while the engine was hot, and cracked a couple eggs into it. After a min or two it stopped leaking
Old 01-26-2020, 08:44 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
I totally agree with the other posters "fix the leak" do not use the pour in crap.
Quick Reply: CYCLO ENGINE LEAK STOP WILL be harmful to engine?? or useful for leakage
