Got pictures of the t-top leak. How do I fix it? Advice needed.
I ran the hose over the t-tops until I got it to leak. Once it started leaking it is like a river inside my car. I've got to replace the carpet and apparently the electronics for the driver's seat as it no longer works. I didn't think my rubber seals looked too bad, but they leak like crazy. Do I need to just replace them all? Or is there something else I can do?
Here are the pictures with illustrations indicating where the water is getting in and the inside of the roof seal. Does it need replaced?
Here is a picture of the t-top seal. Do you think it needs replaced?
This picture didn't turn out well because I had to run around the car and take the picture before all the water finished dripping, but the circles are water.
Your t-tops are seated wrong, take a look at this thread:
https://ls1tech.com/forums/general-m...t-top-fix.html
Apparently mine has been like that for so long that I need new stripping. That or it is also leaking in a different place because when I fixed those places and folded them back where they are supposed to go, the water just came in just a little further inside than before. My wife aimed the hose at the back corner of the t-top and drenched me.
Anyone know where I can get stripping cheaper than the $200 per side from Year one?
