Running rough...again.
Alright heres what happens. I start the car. Its idle immediately drops and car dies, unless I give it some gas and slowly let the gas out until its sitting about idle range then it will sit there. After that when I drive it and I go to sit at a stop light or stop sign or take it out of gear period. The engine ALMOST dies unless I keep my foot on the accelerator giving it gas. Just had a new pcm put in like the dealer said and they said it should fix it. Well obviously it isn't fixed..ugh idk what to do!
I figured out what it was. My battery had a bad connection, so when it was sitting there it would reset the pcm everytime I turned it off. Causing the new pcm to have to relearn everytime I started it. Running great now. Thanks!
