oil leak after cam swap :(
ok i just got done with cam swap and now have oil leak. its not the front main seal/timing cover. its dripping around the oil filter, iwent back and re-tightend all the bolts around the pan and still a small leak. ive searched countless threds on it, is it possible for the dipstick to cause the leak being that i didnt bolt it back 2 the side of the block? its not a bad leak but its irking me being that it didnt leak b4 the cam swap. any help/opinions would be greatly appreciated.
double check the oil filter/put a new one on. You could have slightly installed it crooked or the gasket on it mite not have sealed properly and that would explain why its leaking from that area.
i got the oil changed about 450 miles after and it is still leaking so ima drop tha pan 2mrow and rtv the curners and especially the area where its leaking at.can ne one tell me if there is a certain sequence the bolt are 2 be tightend and the torque specs?
