99 camaro ss window adjustment - LS1TECH
Thread Tools Search this Thread
Old 10-23-2009, 05:11 PM   #1
bambaboy's Avatar
Default 99 camaro ss window adjustment
I have a friend that just bought this car, and I can't get the window to seal against the weatherstip correctly, I've been studying the shbox.com website for a while now and even looked at it while adjusting the window and still can't get it right. Any ideas? could the regulator be worn?
bambaboy is offline   Reply With Quote
Old 10-23-2009, 07:43 PM   #2
Moderator
davered00ss's Avatar
Check general repair & maintenance.
davered00ss is offline   Reply With Quote
Old 10-24-2009, 11:13 AM   #3
Save the manuals!
wssix99's Avatar
Where is it not sealing and how wide is the gap?
wssix99 is offline   Reply With Quote
Old 10-24-2009, 12:33 PM   #4
bambaboy's Avatar
Quote:
the rear top and rear bottom of the window (towards rear of the car) you can almost stick your finder through the gap at the rear bottom, we already replaced the weather strip
Old 10-25-2009, 10:02 AM   #5
Save the manuals!
wssix99's Avatar
This isn't an adjustment issue, then. Something is probably busted.
Pop off the door panel and see if you have one of the two issues in these threads:
http://www.ls1tech.com/forums/genera...-included.html
How the hell do I fix this?? (window related)
Old 10-25-2009, 06:42 PM   #6
bambaboy's Avatar
I think he might have the same issue as the second link, here are some pictures I took, (crappy iphone camera) any suggestions?
Related Topics
Thread Thread Starter Forum Replies Last Post
Z28 manual Windows sink down by self Daulton Shamel Chevrolet Camaro 1967-2002 0 08-22-2016 04:55 AM
Z28 manual window go down by self Daulton Shamel New LS1 Owners - Newbie Tech 0 08-22-2016 04:35 AM
Rotating adjuster window on Koni's beaSSt Suspension & Brakes 1 06-10-2008 05:00 PM
How do you clean your windows?? BrianB Appearance & Detailing 26 06-16-2007 02:54 AM
Tags
2000, 2002, adjustment, adjustments, camaro, car, center, exhaust, fix, gap, motor, mount, pics, replace, slp, ss, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
