Changing T-Top locks need help
Old 11-03-2009, 02:10 PM
00_Z-28's Avatar
Default Changing T-Top locks need help
If this is the wrong form for this question let me know.
So I need to change the lock from my old t-top to my new one. Is there a write up on this somewhere I did the search but come up with nothing. Anyone whith experience in this let me know I'd appreciate any first hand experience. Also picts would be great!
Old 11-04-2009, 08:29 PM
00_Z-28's Avatar
Ttt...
Old 11-04-2009, 11:52 PM
99blkt/a's Avatar
I had mine fall out once, and had to reinstall it. If i remember correctly once you remove the screws that hold the trim on, you should be able to see the lock. There's a big c-clip (for lack of a better term) that holds the lock in. You should be able to pull it and remove the lock, then just reverse the process
Quick Reply: Changing T-Top locks need help
