please help vid inside , switch on prb
Old 11-05-2009, 12:26 PM
PONTIAC SLP's Avatar
Default please help vid inside , switch on prb
hi , when i want to switch on the motor it won't i don't know what is the problem , video below please help guys !! the battery is new i bought it before 2 months ACdelco
http://www.youtube.com/watch?v=6vSqm7L_nKA
Old 11-05-2009, 01:11 PM
LS6427's Avatar
VATS
Your key might need to be replaced too. Sometimes the resistor in it won't let the engien start.
Old 11-05-2009, 01:19 PM
Originally Posted by LS6427
VATS
I did't understand you , how can i replace the key ?
Old 11-05-2009, 01:45 PM
LS6427's Avatar
A dealership must do it for you using your VIN number. That little chip looking thing is just a resistor. I'm not positive, but I think there's like 9 different resistor settings they use for making these keys, so you have to get the correct one. They just take a new key, put it in this little machine and it programs that resistor to what your ignition needs to complete the circuit when you put the key in and turn it on.
Sometimes they get worn out, so that could be it.
There are people on here that know alot about the VATS systems. I don't have that on my 1998 T/A. I think its on the 1999-2002.
Old 11-05-2009, 06:35 PM
Save the manuals!
wssix99's Avatar
Sounds like the battery is dead. What's the voltage on it? Is it being charged by the alternator?
Old 11-06-2009, 04:54 PM
WICKIDSIX's Avatar
Its not the VATS. Normally when there is a problem in the VATS system it doesn't do anything. You Have a click from the starter which tells me the VATS is fine. If the battery id fully charged or it doesn't start by jumping it try taping on the starter while someone else tries starting it. Just have them hold the key in the start position and tap the main housing. Might just fire right up.
