idle problem
Old 11-12-2009, 06:58 AM
+badss+'s Avatar
Question idle problem
my idle rpm is like 500 rpms runs fine it is a descreened mass when its warm and i come to a light it seems like it wants to almost die goes to like 400 rpm but it wont stall out just runs real low,could it be a vacuum leak? what should normal idle be, i just got the car back in may this year car drives good other then that, new to this motor so if anyone knows where to check for the leak let me know thanks......
Last edited by +badss+; 11-14-2009 at 08:45 AM. Reason: guess this site is english class 101.
Old 11-13-2009, 08:56 AM
fleetmgr's Avatar
Dude, there's a reason that capital letters and punctuation are a part of the language.
Old 11-14-2009, 07:09 AM
+badss+'s Avatar
Deleted.
Old 11-14-2009, 07:52 AM
blade2222's Avatar
A vac leak would make it idle higher, try disconnecting the MAF sensor and take it for a spin and see if there is a difference.
Old 11-14-2009, 08:14 AM
eseibel67's Avatar
Originally Posted by +badss+
. yOUR pOINT
If your that lazy, you deserve ambiguous communication.
As far your idle problem, I would first check your IAC counts with a scanner to see if it's responding.
Old 11-14-2009, 08:42 AM
+badss+'s Avatar
Thanks will try it out.
Old 11-16-2009, 04:15 PM
+badss+'s Avatar
Well i took out the plug, it ran almost similar to with it plugged in idles around 550 rpm.
any other suggestions?
Old 11-16-2009, 04:16 PM
+badss+'s Avatar
On a side note the maf is descreened could that be the problem?
Old 11-16-2009, 04:27 PM
eseibel67's Avatar
Does your RPM go down when you turn on the AC?
Old 11-16-2009, 05:43 PM
+badss+'s Avatar
Ill go check
Old 11-16-2009, 05:50 PM
+badss+'s Avatar
Same it dropped too 500 for a split sec then right back to 550ish. but i noticed the lights flickering while ac was on. maybe a electrical issue?
Old 11-16-2009, 06:23 PM
eseibel67's Avatar
Your IAC motor is responding if it went back up to 550 with the AC on. Lights may be flickering becasue the idle is so low. It would still be nice to know what the IAC counts are though.
Is the car stock? I mean throttle body and tune.
Old 11-18-2009, 07:28 PM
+badss+'s Avatar
I believe it is stock tune, it has a descreened maf and no cats... i got it at a dealer so not sure of the history..
Old 11-18-2009, 07:30 PM
+badss+'s Avatar
I planned on doing some of the free mods ive found while searching, so i will be taking the tb off and ill check it its been touched.
