chargin problems
chargin problems
i was hopin this was a sticky..but its not..tho it seems kinda common...ive talked to a few guys with the same problem.
altenator charges fine in park/neutral.
put it in drive it drops to 10..but holds it there..then when you drive it picks back up to 13.4 ish
anybody got any clue to fix this?
they guy i bought it from seems to have put a new battery in it.
lemme know some answers so i can help out a few others around my house.
thanks guys
thanks guys
btw all my mods are listed in the signature..except for the guy i bought it from installed an underdrive pulley..and as i said..it runs out great..ive been in some cars with low volts and they ran crappy..i cant tell a difference in this car at idle or WOT or in between..except for slightly dimmer gauges..and sometims my map lights will stay on but have a slight flicker(my cammed 2nd gen does this to...so i dont think its a huge issue..but my 2nd gen also holds 14 volts =p)
yeah belts tighter then a ticks ***...i talked to a gm factory certified tech and ase in gm and ford..he said it sounds like its just the underdrive pulley since its not dieing or nothing and it should be fine..he said when he had his 347 stroker in his 5.0 coupe he had underdrive pulleys and it done the same thing.
Save the manuals!
with an underdrive pulley all your accessories are spinning at a slower speed... including the alternator. At idle in neutral the rpms are high enough that the alternator can output > 12 volts, but when you put it in drive the rpms drop and that plus the underdrive pulley is causing the alternator to not spin fast enough hence the less than 12v output.
I'll bet that in neutral when it seems to be charging fine, if you turn on your high beams and heater/ac fan on full blast and have your stereo going you'd see < 12v.
the solution is to either get rid of the underdrive pulley, or change the pulley on the alternator to a small one so it'll spin faster at idle, or raise your in-gear idle, or just not let the engine operate at such a low rpm for any duration- shift into neutral and idle up.
