How to change front turn signal lights?
Old 11-20-2009, 02:44 AM
BladeX10's Avatar
Default How to change front turn signal lights?
one of my lights is busted and just bought a new set to swap them out with..The problem is.. How to you get down there to change them out? Looks harder then i thought. lol
Old 11-20-2009, 02:55 AM
eseibel67's Avatar
Actually, it's very easy.
You have to remove the black plastic panels under the car. I think the bolts are 10mm, but I forget. Once you get those off, the bulb is right there.
Old 11-20-2009, 04:42 AM
BladeX10's Avatar
I actually meant the lens not the bulb.. shoulda said that lol.. But i think thats what i need.. Theres a bolt that faces downward on the lens. Ill try it out tomorrow
Old 11-20-2009, 07:53 AM
FirstLSx's Avatar
Getting it out is easy, but I had a hard time getting it back in because I was trying not to damage it.
Old 11-20-2009, 10:05 AM
01ssreda4's Avatar
Those things are a pain in the ***. But yes go through the access panels beneath the car. The bolts are 10mm. Fold the panel downward.
