UD pulley
Old 11-28-2009, 12:24 PM
juniorz28's Avatar
Default UD pulley
Since i put on the SLP UD pulley... It seems that the alternator goes out... For example yesterday i smashed on it on the freeway and when i approached the offramp, the volt gauge seem very low... this is the fourth alternator i have gone thru already.. What can be causing the alternators to die so quick? Any input is welcomed thanx..
Old 12-08-2009, 12:15 PM
Ironxcross's Avatar
What kind of shape is the battery in?
I've had my underdrive pulley for quite some time and I've never had any charging issues. I'm an M6, I'm not sure if you are, but M6 cars tend to idle higher than auto cars.. meaning that it's easier to charge.
I saw you had a cam, I'm not sure if that messes with the charging or not.
Either way, look into the battery and just the connections as well.
Old 12-08-2009, 03:40 PM
02LS1Z28BC's Avatar
Question
When you installed the UD pulley, did you correctly resize the accessory belt? I may be way off here but maybe your tensioner isn't keeping the belt tight because its now too loose due to the pully resizing.
