Oil leak from cam sensor?
I replaced the cam sensor on my 2001 WS6 and have a oil leak. I am not sure if that is where it is leaking or not. I pulled the starter out and degreased the inside of the bellhousing then put the starter back in and started the car. I waited until it started leaking again. I pulled the starter back out and could see the oil running down the top of the rear plate that holds the rear main seal. It is not getting on the flex plate or converter at all. I figured it was the rear plate leaking so I pulled the automatic out and the oil is puddling on top of the plate right behind the cam sensor so I am thinking the new cam sensor o ring didn't seal. I wouldn't think you would put any sealer on the cam sensor o ring. Is that a known place to leak? Any suggestions?
that's probably what happened. especially if it started right after you put the new one in. if the ring on your new sensor is pinched, you might be able to use the o ring from your old sensor and put it on the new one. just put some oil on it to help it slide in without pinching it.
