Coolant Leak - LS1TECH
Coolant Leak
Thread Tools Search this Thread
Old 11-29-2009, 11:39 PM   #1
Midnight00SS's Avatar
Default Coolant Leak
Was under the car today and noticed some drips of water or antifreeze on the bottom of the oil pan, def smelled like it, cant see where its coming from though, water pump looks good, any ideas?
Midnight00SS is offline   Reply With Quote
Old 11-29-2009, 11:51 PM   #2
eseibel67's Avatar
Gravity put the drop on the oil pan. Antifreeze usually leaves a stain. Follow it up until you find the leak.
First I would check water pump or coolant tubes around the TB.
Pressure tester would find the leak quickly.
eseibel67 is offline   Reply With Quote
Old 11-30-2009, 12:07 AM   #3
i just had injectors put in maybe they moved something up top?
Old 11-30-2009, 12:14 AM   #4
Put the front tires up on ramps, start it up and let it warm up for 15 minutes. You'll see it pretty soon after that. Keep looking after shut down too, sometimes they'll leak afterwards.
If you don't see a leak while its running, I'd let it get heat soaked, maybe go for a drive and let it get totally hot. Then come back, put in on the ramps, shut it down and look for leaks for a few minutes. After you shut it down the pressure in the cooling system will rise for a little while, some leaks will only leak at the higher pressures before it starts to cool down.
LS6427 is offline   Reply With Quote
Old 11-30-2009, 01:03 AM   #5
jsteele90's Avatar
check the heater core lines
jsteele90 is offline   Reply With Quote
Old 11-30-2009, 11:07 AM   #6
BIG_MIKE2005's Avatar
YEP, this is how I discovered my water pump was weeping. It would only do it after fully heated & then shutting the car off. Replaced the WP & problem fixed.
BIG_MIKE2005 is offline   Reply With Quote
Old 11-30-2009, 11:45 AM   #7
ok guys im gonna give it a try, and see where this thing is coming from
Tags
antifreeze, camaro, coolant, drip, leak, leaks, leaves, ls1, shut, shutdown, stain, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
