Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > General Maintenance & Repairs
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Used CarsVendor Directory
Search
Leaks | Squeaks | Clunks | Rattles | Grinds
Sponsored by
Gearstar Performance Transmissions
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 12-01-2009, 09:45 PM   #1
Garage is empty, add now
ICEMAN 31's Avatar
Trader Rating: 0
Default Right Blinker won't blink even with new bulb.
So I am driving and I go to switch on my right blinker and the green arrow on the dash stays solid, so logically the bulb must be out. I throw on the emergency flasher to check if its the front or also the back bulb and its just the front, I also notice my front right side fender marker bulb is out. So I go and change them both. Put on some of that autozone bulb grease on it and stick it in. Here is the funny part. It won't blink, but the bulb works, when i hit the unlock on my remote it blinks and when I turn on the flip lights, it goes on but stays on and does not blink. But when the flip light are down it stays off as if it needs to be changed. So the bulb works but its not blinking.
On a side note the side marker light is working fine
__________________
2001 Pontiac Trans Am WS6 A4 Pewter
SLP lid w/ K&N, E-Cutout, BFG Super Sports, FRA!, Raybestos Blue Plate Clutch Kit, Trans Cooler, Trans-go shift kit, 3600 Stall, UMI Adj. Torque Arm 334/350
[b]
ICEMAN 31 is offline   Reply With Quote
Old 12-01-2009, 09:53 PM   #2
2000 Chevrolet Camaro
My Garage
NemeSS's Avatar
Trader Rating: 123
check relay
__________________
NemeSS is offline   Reply With Quote
Old 12-01-2009, 10:15 PM   #3
Anthony Williams's Avatar
Trader Rating: 3
What about the rear bulb? same side.
Anthony Williams is offline   Reply With Quote
Old 12-02-2009, 01:40 AM   #4
myk
1999 Pontiac Trans Am
My Garage
myk's Avatar
Trader Rating: 4
Could be the DRL module too. I remember packing the socket with with grease, trying different bulbs, even replacing the socket, but once I tested the module I found that it was the problem. Wait. Does your T/A have one?
__________________
OMG! Myk's still driving an LS1!
myk is offline   Reply With Quote
Old 12-02-2009, 07:51 AM   #5
Save the manuals!
wssix99's Avatar
Trader Rating: 5
There are two filaments in the bulb. So, you probably have one "working" and the other not.
- What happens when your DRLs are on? (Headlights off) - This is filament #1 for the DRLs and turn signal
- What happens when your headlights are on? - This is filament #2 for the parking lights
- When your turn signals are on, what does the rear light do?
- When your hazzards are on, what does the rear light do?
wssix99 is offline   Reply With Quote
Old 12-02-2009, 09:49 AM   #6
1998 Pontiac Trans Am
Joshiedoom's Avatar
Trader Rating: 4
Send a message via AIM to Joshiedoom
Wrong bulb, bad socket or bad flasher relay.
DRL module is always last.
__________________
1998 Pontiac Trans Am -12.9 at 106-1.92 60'-176k Original Driveline,UMI Suspension, LTs,LS6,TSP TDs,
Joshiedoom is offline   Reply With Quote
Old 12-02-2009, 07:56 PM   #7
ICEMAN 31's Avatar
Trader Rating: 0
-When my drl's (headlights off) are on, only the left light works. Right one stays off
- When my headlights are on both blinkers are on solid but if I turn on the right blinker it just stays solid. left works fine
- My rear right light stays solid when I turn my right blinker on
- when I turn on my hazards my rear light flashes and my front right blinker does nothing
__________________
[b]
Old 12-02-2009, 08:31 PM   #8
jsteele90's Avatar
Trader Rating: 13
Send a message via AIM to jsteele90 Send a message via Yahoo to jsteele90
have you changed the flasher?
__________________
Tick Cam 229/237@111+3/BTR .660 springs/243 Heads/YANKSS3600/3.73s/QA1's/LTS/Chris1313/Extreme Built Trans/ UD Pulley. Tuned by CMS 394/375 Mustang Dyno
11.9@112@3575 DA on old 224 cam setup.updated track times comingwww.socalmuscle.net
jsteele90 is offline   Reply With Quote
Old 12-03-2009, 08:12 AM   #9
Save the manuals!
wssix99's Avatar
Trader Rating: 5
The DRL filament, your turn signal filament, and the hazard filament are the same. Since your DRL is out, your flasher is probably fine. The right side rear probably doesn't flash because the front bulb is "out."
If the filament isn't lighting, its probably the bulb, socket, or DRL module. (In that order.) To be 100% sure its not the bulb, I'd suggest switching the left and right bulbs. If you still have the problem, you should check the socket with a circuit tester. The sockets tend to get fried from the heat of the bulbs - so it may be time to change yours.
Old 12-04-2009, 04:15 PM   #10
chemicalstylez's Avatar
Trader Rating: 0
Send a message via AIM to chemicalstylez
Quote:
Originally Posted by NemeSS View Post
check relay
what he said. its a relay.
__________________
2000 Trans Am WS6 - CAMMED and SLAMMED.
362 RWHP / 358 RWTQ
^---- My Daily driver
1998 Silverado Z71 - 77k miles, super clean
chemicalstylez is offline   Reply With Quote
Old 12-04-2009, 09:26 PM   #11
Save the manuals!
wssix99's Avatar
Trader Rating: 5
Quote:
There is no relay but there is a flasher. If the flasher was bad, the DRLs would work.
Old 12-04-2009, 09:35 PM   #12
Trader Rating: 0
Come-on guys-
the answer is obvious--
he is out of blinker fluid!
op needs to go to auto store and buy some
problem solved
__________________
One accurate measurement is worth a thousand opinions
2001 M6 SS Convertible- Black on Black
Mods: FTRA, Hurst Short Throw, !AIR, Pacesetter LT's, TSP Catted-Y, Magnaflow catback, Whisper lid, SLP smooth bellow, Ported TB, 3.73's, BMR Torque Arm, STB, LCA, SLP Panhard rod, UMI relocation brackets, Nitto D/R's, LPW Axle-Tube Brace, billet grill, 335rwhp/347rwtq
The more we do to you, the less you seem to believe that we are doing it.
proporio is offline   Reply With Quote
Old 12-05-2009, 01:40 PM   #13
Relapse's Avatar
Trader Rating: 4
I had a blinker problem for a while. My front right blinker wouldnt come on or blink when i was driving but when the parking brake was up, the light was dim orange. I ended up saying **** it, and replaced both sockets. Good as new... cost me around 60 dollars for both new sockets and a soldering gun. Soldering was easy... and the fix is good.
__________________
|LS6 Intake|SLP Lid|QTP LTs|TSP True Duals|LS7 Clutch/LS2 Flywheel|
~1999 Firehawk #0363~
|348 RWHP~362 LB/TQ|
Relapse is offline   Reply With Quote
Old 12-06-2009, 01:33 PM   #14
Joshiedoom's Avatar
Trader Rating: 4
Autozone new socket 8 bucks. GM taillight socket. I have quick disconnects on mine with male/female ends. I can change one in a parking lot
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
1999, 2001, blink, blinker, bulbs, camaro, chevrolet, fine, light, pontiac, relay, side, solid, stays, trans, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Statement - JOBS
Emails & Contact Details
