low air volume from vents
Old 12-03-2009, 02:59 PM
mike.d's Avatar
Default low air volume from vents
deleted a.c installed block of panel now i am getting very low air pressure from vents when running heater any body have ideas on what i screwd up thanks guys
Old 12-03-2009, 04:08 PM
91RS383's Avatar
Check that the blower motor is turning on when you turn on the hvac.
Old 12-03-2009, 04:12 PM
mike.d's Avatar
blower motor is running at all speeds
Old 12-03-2009, 04:22 PM
dfred78's Avatar
sounds as if a vent door isnt open, not sure how they work though, maybe by vacuum?
Old 12-03-2009, 04:56 PM
91RS383's Avatar
Yes they are vacuum operated. Check to see if you knocked a vac line loose under the hood. Check for vac at the selector ****.
