simple question which grade oil to use?
There will likely be a firestorm of answers like all oil threads. The recomended oil is 5W30 like stated above. The owner's manual states 10w30 can be used in hot climates. However, 5w30 covers temperature ranges for all but the most extreeme cases.
synthetics do offer slightly better wear ratings but dino oil is just fine, only you can decide if the cost is worth it.
I run Castrol 0w30 because my car spends a lot of time in the garage and I need the start-up protection.
