How to tell if there is a draw?
Old 12-07-2009, 11:05 PM
MTBSully's Avatar
Default How to tell if there is a draw?
I come home from school every few weeks and every time i go to start up the TA the battery only has enough juice to turn the motor over a bit before it the starter starts clicking. It is a relatively new duralast gold battery so im wondering if there is a draw? What is the best way to tell? Thanks
Old 12-07-2009, 11:12 PM
BlueMagicSS's Avatar
Turn off the key, all accessories, close all doors and then take a multimeter and check the battery voltage and then wait about an hour or so and the check it again. This will tell you how much voltage is being drained. OR if you don't have a multimeter follow the first steps and then disconnect and if when you reconnect the negative batt lead it sparks then you have some parasitic draw...
Old 12-07-2009, 11:27 PM
MTBSully's Avatar
what are some common sources of draw? Any ood way to trace it?
Old 12-07-2009, 11:46 PM
myk
myk's Avatar
One, remove the negative cable from the terminal and put a test light between the cable and the battery post. If the light glows, there is a drain. To find what circuit is causing the drain, remove one fuse at a time until the light goes away. Then, install them one at a time. When the light glows there is a drain, when the light is off, the bad circuit was removed. You may not get the light to turn off. In that case, it means that there is a drain in some other circuit that does not run through the fuse panel...
Old 12-08-2009, 02:45 AM
Ok... I just re-read your post... So the car isn't driven daily?? It sits for weeks at a time without starting?? If so then yes the battery will die... If that's the case, disconnect the battery if it's going to be stored for a long time
Old 12-08-2009, 10:24 AM
MTBSully's Avatar
maybe your right. either way if the battery is junk now im hoping autozone will warrant my battery since they are supposed to have three year free replacement
Old 12-08-2009, 11:55 AM
dutinsss's Avatar
red tops are 2 year free replacement, gold tops are 3 year free replacement.
Old 12-08-2009, 02:54 PM
MTBSully's Avatar
yeah mine is gold top
Old 12-08-2009, 06:37 PM
RedGut86's Avatar
Also, I believe you should always have some draw to maintain the memory in the PCM.
As others suggested, what you would need to do to find out if you have a draw you don't want (as opposed to the computer which you would want) would be to remove the fuses for the computer and then test as described above.
Also, the computer draw is tiny so if you have a multimeter the amount of current could indicate whether it is a normal amount or abnormal amount of draw.
Old 12-08-2009, 06:38 PM
RedGut86's Avatar
Oh, and you can just get a little automatic on/off battery tender if you don't want to leave it disconnected and have it reset your computer memory.
