Came back home to drive my Camaro SS
The car had not be ran in 6 months now it hardly stars and jerks all over the place.. Before I left it was having problems would I went WOT.. Friend said it was the clutch slippin.. People now are saying that is the Fuel filter..
Would you all agree with that?
...with cheese.
There's still old fuel in the lines. Take it out for a good drive and run it hard until it stops bucking. Check your battery voltage for ***** and gigs too. Static voltage with the car not running should be 12.4-12.8 approximately. Charging voltage with the car running at <1k RPM should be 13.8-14.3 volts approximately.
You need to be a little more specific on exactly what kind of problem it was having before you parked it also.
...with cheese.
Check your plugs and wires first. Like this other guy said, is it throwing a code? If your check engine light is on go get it scanned and post it here.
I was under the impression that this problem came about after being parked for 6 months. If you were having the problem before it's a different story.
Yeah it was on the dyno twice before I bought the car. We have no dynos in this town and every shop I take it to to tune it says they don't have the equipment to tune the car.
