98 camaro wont crank
the car was running fine, then i started having trouble starting it, spuraticly the security light would come on and nothing would happen when i turned the key. i checked key, it was fine so i decided to change the ignition switch. i went to autozone and the switch they had for a 98 didnt have the security feature so they gave me one listed for a 99, i changed the switch, had the new key made now the security light is off but car still wont crank, i had the ignition and starter relays checked and they were good, replaced the starter and still nothing... any idea???
Not sure, I don't own a code reader, the check engine light is on but I that's normal when the key is on and the engine isn't running right? I've never had his problem until I changed the ignition switch, everything seems to be working fine, I can hear my fuel pump prime and when I turn the key to start the headlights go off and I can hear clicking under the hood but nothing from the starter... I have bridged the starter and the car will run that way but not by turning the key
How manby volts in the battery? Is it fully charged?? Starter could be bad
