oil pan gasket?
Old 12-26-2009, 10:09 PM
bpt071's Avatar
Default oil pan gasket?
anyone got the procedure to doing this? i noticed i had a leak on it and wanted to take care of this.
Old 12-27-2009, 06:36 PM
bpt071's Avatar
no bites
Old 12-27-2009, 07:10 PM
jsteele90's Avatar
drop the k member a few inches to remove the oil pan. replace gasket. install sealer at the 4 corners. install pan. reinstall k-member
Old 12-28-2009, 11:02 PM
Scira's Avatar
It's going to be a PITA. I've been looking into it for the last month. I'm not looking forward to it.
Old 12-30-2009, 12:43 AM
jsteele90's Avatar
after my heads and cam swap i had a oil leak. i removed all the oil pan bolts added sealer to the front two corners. tightened it back up. no more leaks !!!!!!!!!!!
Old 12-30-2009, 12:14 PM
Scira's Avatar
Do you have any pics of what you did? All you did was remove the bolts, sealer, then put the bolts back in?
