P1071 & P1074 codes came up
Old 01-16-2010, 07:29 PM
bad_408_vert's Avatar
Default P1071 & P1074 codes came up
Hey fellas, these two codes came up on scanner.
P1071, p1074
all searches online lead to countless things.
I'm wondering If anyone can shed light on what could be causing it.
Old 01-16-2010, 08:00 PM
99huggerorangeZ's Avatar
check for an intake leak,what engine? there is a gm tsb for 5.3/6.0l engines that have a revised intake gasket set due to faulty gaskets,causing both the p0171/p0174 codes to fault.
Old 01-16-2010, 08:16 PM
Thanks 99z
this is for a friends o1 v6 3800 series 2 motor.
Everything looks good around the intake.
Bad maf sensor or dirty maf?
Old 02-19-2010, 02:09 PM
FastRidesOnly's Avatar
DTC P0171 Fuel Trim System Lean Bank 1 DTC P0174 Fuel Trim System Lean Bank 2got these codes after changinge fuel pumpwhere are the leaks?is cut my trunk to access the trunk.is it just one of the hoses not snapped back in tight. or cuz the metal lid on t
Old 02-19-2010, 03:51 PM
check pcv valve
Old 02-20-2010, 01:11 PM
CAMJAG's Avatar
I had both of those codes come up in my 98 Z28 as well. All data suggest injector leak, or foul injector, and exhaust leak.
Quick Reply: P1071 & P1074 codes came up
