no spark no fuel pressure
what could my problem be? when I turn the ignition on i could hear the fuel pump run but when I try to turn the car on, it wont turn on it just turns over and over again. the coils do not deliver the signal to the spark plugs so i also dont have a spark. I also dont have fuel pressure. I checked the fuses and relays and they all seem good. thanks for your help
would that also be the cause for no spark? or would that be a whole different problem? because if they are different problems its weird that this happened all at the same time
i took off the spark plug and with it still connected to the spark plug cable and the coil, touched the spark plug to the engine block, cranked the car and there was no spark
