Top dead center
Old 01-27-2010, 11:53 PM
daws222000's Avatar
Default Top dead center
What is the easiest way to find top dead center of the piston with the heads on. Can i do a leak down test if the motor is not warm.
Old 01-28-2010, 12:29 AM
LS6427's Avatar
A guy checked mine for me years ago, he had this little "whistler" that he attached to the end of the air hose. Popped the proper fuses (fuel pump and one other I think) so the engine couldn't fire up, then he had me slowly bump the key to turn the engine over little by little. When the whistle sound stopped, that piston was at TDC. Then he took the whistler off and attached the air hose and did the test on that cylinder.
Old 01-28-2010, 02:26 AM
eseibel67's Avatar
Remove #1 plug. Stick a long plastic drinking straw in the hole. Turn engine by hand (by the crank bolt) until the piston pushes the straw out as far as possible.
Old 01-28-2010, 02:45 AM
hotrodscrap's Avatar
Piston stop(like what comes in a cam degree kit) in #1 as previously stated.
-SS
Old 01-28-2010, 05:49 PM
1994Z28Lt1's Avatar
it depends on the engine with an lt1 its probably easier to just pull a valve cover and watch the action of the rockers as your turning it over, not as easy with a ls1 because of the coils in way
you didn't say how exact your trying to be either i guess if your just trying to get the valves closed so you can do a leak down test.... so who knows....
Quick Reply: Top dead center
