Abs tcs brake light?????
Old 02-01-2010, 10:51 PM
98z-28redcamaro's Avatar
Default Abs tcs brake light?????
driving down the road the abs tcs and brake light comes on... its annoying... anyone know the problem??? it done the same thing when it was on the dyno and it went off a few miles down the road. now its not going off until i cut the car off
Old 02-02-2010, 04:31 AM
Mr.z/28's Avatar
Do you mean when your driving at a certain speed and a certain amount of minutes, The e brake and in op abs would turn on?
Do you have different size tires meaning a offset to your car. Mine does that because I have smaller tire up front and bigger tire out back. Our cars were program to have I guess the same size tire all around.
Its no problem.
Old 02-02-2010, 10:18 AM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,458 Likes on 1,051 Posts
Sounds like a bad wheel speed sensor.
Old 02-02-2010, 12:06 PM
my rear end is leaking a lil out of the side seals.... tick tried to get it to stop but they only slowed it down....think thats the prob... its a 4 channel abs rearend
Old 02-03-2010, 12:29 PM
NBM-LS1's Avatar
Yes our cars were designed to have all the same tire size on them. The ebcm wont be able to control the tcs because it wont be able to calculate the individual wheel speeds since the fronts are different from the back.
Old 02-04-2010, 01:13 AM
rdd014camaro's Avatar
If all those lights are coming on at the same time it is most likely your EBCM(electronic brake control module) The relays inside of it were cheap and go out pretty quick. You need to take that off your car and have it sent out and rebuilt. You can take this part off your car and still be able to drive it if it is your daily driver, you just wont have ABS. just type in EBCM repair in google and you will some links to people that offer the repair I think the average rate is like 150 bucks. Or you could by a new one from GM which cost like a grand I think. Take it to a shop that has a thorough computer reader as the basic obd2 readers are unable to read these kind of codes. The shop will be able to tell you exactly what the problem is if that is not the problem.
Old 02-04-2010, 01:50 AM
need4fun2469's Avatar
i have the same problem.
I am going to remove all abs/tcs hardware and wiring harness.I don't need any of it.
Old 02-04-2010, 02:02 AM
Thats the best way to do it! Before ABS and TCS came out I wonder how people survived lol. My 68 camaro was no vacuum boosted 4 wheel drum brakes, talk about crappy brake system.
Old 02-04-2010, 08:40 AM
Spartan7's Avatar
I had an issue with my BRAKE, LOW TRAC, ABS INOP, and ASR OFF intermittently flashing on then off during normal driving (not even braking), and it turned out to be a loose ground in the engine bay.
The leaking axle seal problem is easy to fix. Pull the axles out and replace the seals.
Old 02-10-2010, 11:20 PM
ecuxc's Avatar
I had the same issue with my previous 2001 SS. Since I was used to not having ASR/TCS and ABS (1990 RS 305 previously owned) I did not make any repair. I just removed the cluster and covered the LEDs for the Brake, ASR, and ABS. Drove approximately 30K miles with no problems before I had to trade her.
Old 02-11-2010, 05:44 AM
koolaid_kid's Avatar
There is a calculation made (IIRC, it is 97%) and if the front and rear are off by more than that it will switch ABS off and set the light. I have an electrical issue with mine; when I have my foot on the brake and the ABS light comes on, I can feel the difference in the pedal.
I prefer ABS, but that's just me. It has saved my azz more than once, and I wish I had it yesterday on my DD when I slid through a stop sign b/c I did not see the ice patch on the road.
Quick Reply: Abs tcs brake light?????
