Wiring question..
Wiring question..
There is a wire in the LS1 Harness that goes to the PCM called the Theft Deterrent Fuel Enable
Going on a hunch here..that is the one signal wire that the Key Chip tells the PCM it's the correct one and it enables the Injectors.
Now if the VATS is disabled, can that wire be removed without and issue..?
Just a thought, if I was home I would un-pin it and see for myself.
