OIL sending unit.....how do you remove that sucker..........
Old 02-17-2010, 05:55 PM
LS6427's Avatar
Default OIL sending unit.....how do you remove that sucker..........
I have the intake off and its right there. I don't have a socket long enough to slide over the top and still reach the nut on the bottom.
Do I need to spin that silver nut portion of it near the bottom of the sensor? I wanted to ask because I keep hearing how easily these things break. I want to clean it, it has to be dirty after 12 years. Oil pressure needle has been a little jerky lately and acting wierd.
Also, the MAP sensor is the on the back of the intake, right? Is there another name for it, parts stores can't find it when I tell them MAP sensor. Might as well change that thing too while I'm in there.
Old 02-17-2010, 07:41 PM
fleetmgr's Avatar
Oil pressure senders take a special socket, and it's not used for anything else on the whole car. Any parts store will have it.
MAP problem is the lack of intelligent life where ever you're going. Try a real parts guy at NAPA.
Old 02-17-2010, 08:41 PM
2000TransAm24's Avatar
I bought the "special socket" from napa for the oil sending unit and it didn't work for me. Ended up breaking the sensor off and using an 1 1/16 socket to remove what was left. It's a 50$ sensor maybe you can find an 1 1/16 deep socket that is long enough. The new sensor is a different size, can't remember what tho.
Old 02-17-2010, 08:56 PM
97camaross's Avatar
I have pulled at least 50 oil pressure senders off using the special socket(you can get it at any parts store or snap-on guy) and never have one break. but if it were me and it were 12 years old I would just replace it any ways.
and you could also ask the parts guy to look up manifold absolute pressure sensor(MAP) maybe they have it cataloged under that.
http://www.oreillyauto.com/site/c/se...ird&vi=1305458
Old 02-17-2010, 09:20 PM
lil-bit's Avatar
would that oil pressure sender make the gauge read zero sometimes even though the engine has good pressure and the dip stick is reading perfect??/?
Old 02-17-2010, 10:25 PM
slayerized6's Avatar
^^ if you ran your engine with 0psi oil pressure for more than 30sec, you would have major problems. So unless your engine sounds like its about to explode, your OPSU is defintly faulty
Old 02-17-2010, 10:49 PM
97camaross's Avatar
yes...
Old 02-17-2010, 10:59 PM
eseibel67's Avatar
Ask that kid at the parts store to look up your MAP sensor under the "fuel/air" subgroup. He was probably looking for it in the "emissions" section.
Old 02-18-2010, 05:24 PM
LS6427's Avatar
Thanks fellers.
The oil pressure is working, it just does some wierd **** frequently. Can the OPSU be removed and cleaned?
Old 02-18-2010, 05:26 PM
LS6427's Avatar
Whats the symptoms of a failed MAP sensor?
Old 02-18-2010, 06:48 PM
97camaross's Avatar
reduced engine power...and the OPSU can not be cleaned just buy a new one and save you the trouble
Old 02-18-2010, 06:54 PM
LS6427's Avatar
Well, before this coil firing issue which caused me to have to remove my intake to replace the camshaft position sensor......I had absolutely no loss of power problems. So I just sprayed the MAP sensor clean with Sea Foam spray.....I guess my MAP sensor is fine.
I'll get a new OPSU tomorrow and toss it in. My stepfather has an open-end 1-1/16" wrench that should go right over the top of the OPSU.
Thanks.
Old 02-18-2010, 08:45 PM
fleetmgr's Avatar
Good luck, you'll probably end up getting the socket anyway. If the wrench would work, nobody would make the socket.
Old 02-18-2010, 10:34 PM
LS6427's Avatar
My stepfather has these very unique tools at his work. He's an engineer at a food processing plant, he keeps all the machinery and assembly lines running. If the wrench end is thin enough around it to get inbetween the sensors' nut and the LS6 valley cover, it'll work. It looks like its maybe a 1/8" thick space. He's not sure how thick the end of the wrench is. I'm sure that tool is pretty expensive. I'll find out tomorrow.
Old 02-18-2010, 10:43 PM
ae13291's Avatar
you cannot clean the oil pressure sensor but you can clean the MAP sensor, i remember mine was all oily when i removed it.
Old 02-18-2010, 10:44 PM
Nemesis350's Avatar
I thought i could get a wrench around it too,...and honestly? Didn't work. Get the socket, it's maybe $10 at Advance, and probably a similar price wherever they sell auto parts.
Old 02-18-2010, 10:46 PM
LS6427's Avatar
If they have one when I'm there tomorrow morning I'll grab one.
Old 02-18-2010, 10:47 PM
LS6427's Avatar
I cleaned it pretty good with Sea Foam spray.
Old 02-18-2010, 11:43 PM
Nemesis350's Avatar
Did it fix your problem?
Old 02-19-2010, 12:21 AM
LS6427's Avatar
My intake is still off, gonna clean it tomorrow, put the new camshaft sensor and OPSU sensor in and start it up. If its not missing anymore my problem was a bad camshaft sensor.
What I was saying earlier was that I didn't have the symptoms of a bad MAP sensor so I'm sure its fine, I just cleaned it out since its off the engine.
Quick Reply: OIL sending unit.....how do you remove that sucker..........
