steering wheel becomes VERY loose when you hit a bump.
Old 03-02-2010, 10:40 AM
Justin0828's Avatar
Default steering wheel becomes VERY loose when you hit a bump.
not sure what this is if its my shocks or what.
my ta is a 98 and has 158k miles. runs strong as hell but when i hit a bump the steering wheel becomes very loose. the car handles fine its just hitting bumps is horrible.
anyone have any ideas what needs replaced on my old baby
Old 03-02-2010, 10:50 AM
99huggerorangeZ's Avatar
i would check your inner/outer tie rods.
Old 03-02-2010, 01:52 PM
fleetmgr's Avatar
With 158k, it's probably time to overhaul the whole front end.
Old 03-02-2010, 02:17 PM
NDFORSPD's Avatar
Could be either the struts/shocks(esp if they are orig or stockers....or worse orig stockers!!) or a sloppy tie rod as mentioned above
Old 03-02-2010, 02:45 PM
thatguy383's Avatar
i think mine does this with 50,000 miles... might mostly be the car, I'm used to german stuff (this was not helpful I know)
Quick Reply: steering wheel becomes VERY loose when you hit a bump.
